Abs light flashing
171,458 MILES • 4.2L • V6 • 4WD
ANDY FEARON
The brake and ABS lights are flashing at me, and I have an ABS pump motor malfunction code.
Aug 22, 2016 at 2:05 AM
HMAC300
  • 48,601 POSTS
you will have to replace the ABS unit at least which must be programmed by a mechanic to your truck as well as bleeding the system. if ABS is on your ABS will not work, but you will have normal non ABS brakes.
Aug 22, 2016 at 2:29 AM
ANDY FEARON
Can I replace just the control module or do I have to replace the whole unit and have the brakes bled?
Aug 22, 2016 at 2:38 AM
HMAC300
  • 48,601 POSTS
if you replace the control module it has to be programmed, but the pump motor is part of the ABS unit not the module.
Aug 22, 2016 at 2:48 AM
