ABS actuating after replacing axle and bled brakes
177 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
ZELLDOG93
  • 111 POSTS
Replaced axle bled brakes and now I have my ABS actuating on slow gentle braking. I am curious to know if there is ABS bleeding procedure I am unaware of? As well as having one wheel a mismatch size I have 3 2254517 and 1 2055516 as a spare until wheel is repaired.
Oct 16, 2018 at 6:45 AM
  • 55,711 POSTS
Bleeding the brake will not cause this. It sounds like the corner you were working on is having a problem with the sensor. Can you check to make sure the sensor is in right and that it can read the reluctor as well?
Here is a video that will help you read the codes to confirm:
https://youtu.be/rTtAnsOlZU4
Cheers, Ken
Oct 18, 2018 at 3:18 AM
