ab,esp, and low tire lights
120,000 MILES • 1.9L • 4 CYL • TURBO • FWD • MANUAL
SCOTTLOHR
Hi I had 3 lights come on when I hit 50 kph that is the abs, esp, and low tire light, I fixed the rear breaks, which I new needed fix and replaces the abs sensor's in the back since I heard the noise back there when the lights started to come on, but now they stay on right after starting the car. I tried to un-plug the battier Pos side to reset but now I still have them light on plus the light that looks like a steering wheel is on and stays on. Any idea how to get them to go out again.
Thanks
Scott lohr
Jul 17, 2014 at 6:24 PM
WRENCHTECH
  • 20,760 POSTS
The first thing you need to do is get the ABS codes read to have a starting point.
Jul 17, 2014 at 7:33 PM
SCOTTLOHR
Ok but why did the steering wheel light come on and stay on when I un plugged the battier, and now it wont go out. Kind of bad that one can't change there battier without having to take it to a shop for a computer reset. I should be able to do it without taking to a shop .
Scott
Jul 17, 2014 at 8:26 PM
WRENCHTECH
  • 20,760 POSTS
Electronic programming can be lost when power is disconnected although it usually doesn't.
Jul 17, 2014 at 8:34 PM
