ABS and VSC lights on?
65,000 MILES • 4 CYL • 4WD • AUTOMATIC
CATY228923
I would like to know what this means and how much it will cost to fix it.
Mar 22, 2025 at 10:51 AM
  • 55,508 POSTS
When this warning light is on it means the ABS and traction control safety system is not working. This guide can tell you more:
https://www.2carpros.com/articles/what-an-airbag-light-means
The cost depends on what the problem is, which can be known if the trouble code is retrieved. Which can be done if you watch this video:
https://www.youtube.com/watch?v=Pb6nXV-iamI
Usually, it will be a wheel speed sensor with will cost about $170.00 installed with the codes cleared. Please let us know what happens.
Mar 23, 2025 at 3:21 AM
