A/t temperature light
153,889 MILES • 3.1L • 4 CYL • TURBO • 4WD • AUTOMATIC
JUZIF NIL SUR
The A/T temperature of my vehicle is always on, and when i shifted to drive it seems like sliding. It need high rpm in order to run the vehicle. But when i shift to reverse, second gear and low gear it was wonderful. Is this the clutch pack? Or the ATF cooler? Help me please.
Jun 2, 2017 at 8:25 PM
HMAC300
  • 48,601 POSTS
have a transmission specialist look at this from the sounds of it. it may be a clutch pak bad or a seal in the clutch pak bad. we do not have that model in US so no information on it if you can check fluid level make sure it is full when hot.
Jun 2, 2017 at 11:11 PM
