A/T System Malfunction?
270,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
HONDAACCORDVTI
Hello! I bought the car listed above with a 2.4l VTi and engine light popped up when i started the car, also when i turned to bigger street and drive a bit faster (over 40kmh i think) the D started flashing. Mechanic searched for codes and that came up (picture attached). I have driven it a couple of days like that and haven't noticed anything weird from gearbox. After a fresh start, D starts flashing after higher gear change (3rd to 4th i think) i have noticed.
Mar 23, 2025 at 4:58 PM
  • 55,721 POSTS
I don't see the image can you please reload it or just tell me? I have seen the input shaft sensor cause this issue, here is the location but it would be better if I had the code. Let us know how it goes Check out the images (below). If you change the sensor out, you need to clear the codes after.
Mar 25, 2025 at 7:16 AM
