A rumbling sound
125,000 MILES • 4 CYL • FWD • AUTOMATIC
LEROY MEECE
I notice to hear a weird sound coming from the front of car. I can tell its not engine noise. At first i thought it was tire being worn cause they were in bad shape. Then put new tires on and issue still the same. So I thought maybe transmission but shifts great and when I am going down the highway I would put in neutral and still the same sound except when slowing down I hear the sound going down. Any ideas? This is an automatic transmission.
Apr 13, 2017 at 2:36 AM
HMAC300
  • 48,601 POSTS
it may be a wheel bearing going bad, try driving i a circle one way then another if it is louder one way then it is on the opposite side. also, if it is a screeching type sound and when you hit your brakes it goes away you may need a brake job.
Apr 13, 2017 at 2:40 AM
LEROY MEECE
As I would had expected
Apr 14, 2017 at 2:58 PM
  • 55,710 POSTS
Here is a guide to help you see what needs to be done to get the problem fixed.
https://www.2carpros.com/articles/bearing-hub-replacement
Please let us know what you find so it will help others.
Best, Ken
Apr 17, 2017 at 8:45 AM
