noise coming from dashboard rattle
140,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
ALZACK41
  • 20 POSTS
VIN 4T1BF28B2YU022042.
The problem started about a year ago.
It took some time and experiments to locate the trouble place.
A rattle noise started coming from the top plate/bar on the dashboard.
This plate/bar is made from a soft flexible material.
Under that plate/bar goes a thin black plastic tray, snap connected to that top plate/bar.
The noise never comes on when the car is moving.
The rattle noise is coming on only when the car is on idle
(the engine running, the gear engaged, but the car is not moving - typical for
stopping on red light, parking, etc.).
Trying to eliminate this noise, I noticed:
A) Turning off the blower motor helps for a short time,
then the noise comes back again.
B) Turning A/C off or on does not affect the noise.
C) Disconnecting and removing the plastic tray from the top bar/plate did not help.
D) After disconnecting the plastic tray, putting shims under the bar/plate did not help.
E) The only thing that helped was this: with the plastic tray originally snap-connected to the top bar/plate,pressing them to each other in two points, 3" right and left from the center,with a heavy-duty 2" spring clamps helped to almost eliminate the noise. It was clumsy, but it worked.That gave me a (crazy?) idea of drilling at those points for putting screws, that will press those two pieces to each other using nuts, smaller and larger washers (steel and rubber). I did not do that yet.
I understand, that if I do I will need a Right Angle Drill.
Note:
Motor mounts, suspension, steering system are recently renewed.
Please suggest on how to fix my problem without going to the dealer.
Albert
May 30, 2018 at 1:49 AM
  • 55,608 POSTS
Hi Albert,
Be glad to help but with noises. It is best if you make a short video with your phone of the problem noise etc., and upload it here in your reply so we can see whats going on. At least pictures. :)
Please let us know.
Cheers, Ken
May 31, 2018 at 4:39 AM
ALZACK41
  • 20 POSTS
Hello Ken.
The video you requesting certainly will not give you any idea about noise itself or that noise location.
Please better tell me if idle RPM can be increased about two to three percent on my car.
I noticed that the rattle noise (coming from the dashboard shell structure) takes place when the engine is running, the gear is engaged, brake pedal pressed down, and the car is not moving.
At this point the RPM is the lowest.
As soon as the car starts moving even just a little, the RPM increases, and the rattle noise stops.
I think it is because the lowest RPM makes a resonance phenomenon (dashboard shell resonates to the low frequency mechanical vibration).
So I wonder if the idle PRM can be increase two to three percent on my car and VIN number listed above.
Albert
Jun 1, 2018 at 7:01 PM
  • 55,608 POSTS
The RPM is adjusted by the PCM. I am thinking engine mounts would cause this problem as well. After a few years they become hard and do not insulate the engine vibration.
Jun 2, 2018 at 5:35 AM
ALZACK41
  • 20 POSTS
Hi Ken,
You wrote:
"engine mounts would cause this problem as well. After a few years they become hard and do no insulate the engine vibration".
My answer:
All engine mounts were replaced by new ones several months ago.
So we have to concentrate on the second option, which is
increasing the engine RPM by using PCM (and/or some other means).
Please give me a detail instruction on how to do that
If it is possible to do, could a local car mechanic do that?
I appreciate your effort.
Albert
Jun 2, 2018 at 7:16 AM
  • 55,608 POSTS
Did the vibrations start after the engine mount were replaced? What was the reason for the replacement? Also, to raise the idle of the engine is not logical and will make the car bang went it goes into gear. Can you tell if the engine is vibration excessively?
Jun 3, 2018 at 4:21 AM
ALZACK41
  • 20 POSTS
You asking:
My answers:
1) No, the dashboard structure vibration/rattle was noticed long before the engine mounts replacement.
2) The dashboard structure vibration/rattle when on brakes at the red light was the reason for the engine mounts replacement.
But that replacement did not help.
I suspect that one of the replacement mounts was defective.
The picture of that part is attached.
Its Toyota original number is 12307-20021, part code 12307.
That motor mount is also called "Engine Shock".
But as I remember, the cylinder and piston of that part were
moving freely up and down without any resistance.
That is not the behavior of shock absorber.
So I will study other equivalent parts for shock absorbing operation (Auto parts Stores and Dealer's place) and will do a new replacement if needed.
3) I agree with your statement:
"To raise the idle of the engine is not logical and will make the car bang when it goes into gear".
Jun 3, 2018 at 3:52 PM
  • 55,608 POSTS
I have seen torque converters, harmonic balancer the come apart making the engine vibrate. Can you tell if this is an engine problem?
Jun 4, 2018 at 3:17 AM
ALZACK41
  • 20 POSTS
Thank you Ken for your time and effort.
You did good. Thanks again.
Albert
Jun 4, 2018 at 11:31 AM
  • 55,608 POSTS
Cheers, Ken
Jun 4, 2018 at 11:49 AM
