While driving home the van just shut off and would not start, had it towed home?
189,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TIREDE
Had timing belt replaced 2 months before the problem, driving home van just shut off, wouldn't start had it towed home. The next day cranks over, no start, finally got it to start, running really rough and valves rattle, when given gas loss of power. I put the scanner on and get no codes, replaced crank position sensor, cam position sensor idle control valve, coil, wires, plugs, fuel pump and filter, it's getting spark, fuel. after all of that, I took it back home because the garage here in my town likes to rip people off I found out thank you very much. I'm at wits end, and known has an answer. I've been on the web and called all over, and all that work done, hasn't changed a thing, still won't start most of the time when it does, low power, valves rattle like crazy, it has been well cared for, and I need it and can't afford to buy another vehicle, I am pretty mechanically inclined, I don't know what else to do and desperately need help, I was giving up and then I ended up here, I would appreciate your advice ,as this is my last ditched effort, I've been dealing with this for 3 month, it doesn't smoke, no backfires, I don't get it, thank you so much for what you people do, I'm not a mechanic but kind of the same thing is happening to my 2012 chevy malibu 2.4liter. I also had my timing belt replaced in Nov. When mine dies and won't start back I take the battery cables off hold them together for 60 sec. Then leave them off for 30 min. Or pull out the ECM Fuse and put it back in. My car also doesn't throw any codes and it sounds like a rod is going to come through the motor or something when it's about to shut off. I'm going to try to replace the crank shift position sensor hopefully that's what it is. Good luck, I hope we both figure it out! Thank you for your time.
Aug 25, 2023 at 1:35 PM
TARANOEL
I'm not a mechanic but kind of the same thing is happening to my 2012 chevy malibu 2.4liter. I also had my timing belt replaced in Nov. When mine dies and won't start back I take the battery cables off and hold them together for 60 seconds. Then leave them off for 30 min. Or pull out the ECM FUSE and put it back in. My car also doesn't throw any codes and it sounds like a rod is going to come through the motor or something when it's about to die. I'm going to try to replace the crank shift position sensor hopeful that's what it is. Good luck I hope we both figure it out!!
Aug 25, 2023 at 11:26 PM
  • 55,711 POSTS
I need to hear the engine cranking over and running. can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. I think the engine is hurt but I need to make sure. This guide may help in the meantime:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and get back to us.
Aug 26, 2023 at 6:24 AM
