A lot goes wrong with this
150,000 MILES
THEBIGIB
I'm trying to figure out why my one side of the car is lower at the from then the other side I think its upper control arm cause I shake tire and I see and hear the control are where it connects to knuckle moving around. mechanic keeps saying it good but I really dont think its is
May 13, 2013 at 1:31 PM
CARADIODOC
  • 34,391 POSTS
First you need to find a different mechanic. Try a tire and alignment shop. They specialize in solving ride height, alignment, and noise problems.
Second, height problems relate to the springs. Correct height is critical for proper tire wear. Even when the numbers look good on the alignment computer there will be excessive tire wear when ride height is not right because the suspension parts will be in the wrong geometry.
Most importantly, Ford has way more trouble with steering and suspension parts separating leading to loss of control and crashes than all other manufacturers combined. Noises and handling problems must never be ignored. Those systems should be inspected once a year and when you notice anything unusual.
May 13, 2013 at 5:27 PM
