Serpentine belt installation
86,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
CHADTRODGERS
I have a the car listed above that I need to put the belt back on the pulleys. I’m having a problem getting to the tensioner. I have the serpentine belt wrench set from AutoZone, but I just cannot get the darn thing on the tensioner to loosen the tension. Next issue: once I do finally get to it. I’m hoping from underneath where there is a gap in the underside guard of some kind , apparently I will need to be able to keep a hand on the wrench while re-setting the belt?? Please help soon if possible. I’m headed back over to the car I awhile to try again. Thank you for any help on the matter sir.
Jan 26, 2020 at 1:50 AM
Good afternoon,
I usually get this from inside the right front wheel well. If you remove the cover, it will be much easier to access the tensioner for installing the belt.
Jan 26, 2020 at 2:14 AM
