My car jerks
180,000 MILES • 3.2L • 6 CYL • RWD • AUTOMATIC
RANYRIZK
  • 39 POSTS
While the car change reduction ratio I feel a jerk.
My scanner gave codes; P0700, P1865.
Canyou help me?
Regards.
May 19, 2016 at 11:36 PM
HMAC300
  • 48,601 POSTS
700 is a general transmission. Code 1865 is a 4-5 shift solenoid problem of too high a voltage or shorted system. It can actually be a clutch pak problem as well. Have a transmission professional give you an opinion and make sure the transmission fluid is full and not dark brown or black. If it is, then most likely there is a problem with clutches/seals inside transmission.
May 20, 2016 at 12:28 AM
RANYRIZK
  • 39 POSTS
Dear
The transmission fluid is acceptable.
All the solenoids of the valves-body are working well.
The code p1865 exits still.
Could you help me please?
May 23, 2016 at 11:31 PM
HMAC300
  • 48,601 POSTS
in my first reply I said it could be a clutch pak problem or and internal problem so a trans guy is going to have see what has happened.
May 24, 2016 at 12:02 AM
