when I turn on the air it runs for a while then it goes off. I have to stop and lift the hood and tap on the resistor. it will only run on high.
Feb 12, 2018 at 7:01 AM
✓Experienced Mechanic
Good evening.
Do you mean the blower motor?
Feb 12, 2018 at 7:07 AM
RONALDHARPER50
MEMBER
Yes I all ready tried another blower and it does the same thing
Feb 15, 2018 at 12:28 AM
RONALDHARPER50
MEMBER
I 'm talking about the little silver thing in front of the blower
Feb 15, 2018 at 12:33 AM
there is a blower resistor by the blower motor that controls the speeds. it sounds like you have changed that already. if you did, check for voltage at the wires in the lower fan speeds.
if you have voltage check the connector at the resistor and the blower motor.
if you do not check all fuses in the fuse panel for power on both side with the key on
Feb 15, 2018 at 12:49 AM
RONALDHARPER50
MEMBER
The blower motor is running just not fast enough.
Feb 15, 2018 at 8:57 AM
It sounds like you have a bad ground for the blower motor can you use a test light and with the test light grounded and the system one touch the metal housing of the blower motor to see if it lights up?
