Just recharged the A/C unit. When i am driving, i always get heat on the floor vent. And when i put the A/C on, all i get is very hot air blowing, not cold. I replaced all the vacuum lines in the engine area, checked all the actuators inside the dash, even used a vacuum tester to make sure they are all working. Once i hear clicking noise after i replaced the blend door actuator and looked and seen that it looked like it opened up or came apart. What a headache replacing that. So, i replace it again to see if this is the problem with the A/C unit not blowing cold air? i can do this again if i have to.... Main reason i need the A/C working. thanks for any help.
May 26, 2024 at 2:31 AM
