A/C will not get cold?
100,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
SHANE10
The A/C doesn’t get cold, the compressor clutch stays engaged and the fans on the radiator stay on. Freon level seems right as well. The A/C gets cool but not cold.
Aug 12, 2023 at 10:57 AM
  • 110,248 POSTS
This could be a few things. First, how was the Freon charge checked? That is the most common cause.
Take a look at this link:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Also, the A/C condenser is located in front of the radiator. It looks like an additional radiator. make sure it isn't dirty with debris. If it is, spray it out with a garden hose.
Here is another link you may find of interest. If discusses possible causes of an A/C not working or weak.
Let me know if any of this helps or if you have questions.
Aug 12, 2023 at 3:43 PM
