A/C was kicking on and off, now does not want to kick on at all
2006 HONDA RIDGELINE
173,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
RV3MAKER
Last year I had the high pressure vapor line leak. I believe it is because I used some fill and later found our it had green gunk in it. My bad. I replaced the line, pulled the condenser, drained the green crap out, replaced the drier element in the condenser, added the proper oil kind and amount and proper amount of coolant and it worked great for the last year. This spring it started not working, then would kick on and work fine. It was working for several weeks straight, just fine after it got warmer . . . I went on vacation for a week and came back and it has only worked 1-2 times since. Compressor kicked on and seemed to be dragging a bit. I do not believe the compressor has kicked on in some time. A pressure check of the system today shows low side at 110-120 psi fluctuated a bit but steady at 120 when hot. High side is rock steady at 125 psi. Not sure where to start on this . . . I don't want to just assume the compressor and spend that money. I have the Ridgeline manual and I am going to start going through it. Any suggestions on where to start?
Jul 4, 2014 at 5:35 AM
HMAC300
  • 48,601 POSTS
your compressor isn't working so check to see if the fuses and relay s are good switch with a like relay. if this doesn't work then have it scanned because it may be one of themodules that run this. I am assuming this is manual a/c if it's auto temp where you set the tem p then have it scanned as it could be anything.
Jul 4, 2014 at 6:05 AM
RV3MAKER
I will get it scanned and check the codes as it is a temp set/auto system. thanks
Jul 4, 2014 at 7:05 AM
