A/C ventilation problem
75,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
STEVE529
A/C doesn't blow out air on dashboard vents.
Jul 21, 2019 at 3:23 AM
  • 55,721 POSTS
This sounds like you have a mode blend door actuator that is not working due to lack of vacuum probably a broken vacuum line here is a guide to walk you through the repair with diagrams and instructions to show you how on your car below.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Jul 22, 2019 at 8:12 AM
STEVE529
Thanks for the helpful information. Do you know how much this would cost to get fixed at a garage?. Thanks again for the help.
Jul 29, 2019 at 8:33 AM
  • 55,721 POSTS
If the problem is a broken vacuum one under the hood about $35.00 but you should check your self its an easy fix. Use a flashlight and check out the guide above it shows what to look for.
Jul 30, 2019 at 3:46 AM
