A/C system will not go below 25 inches of water at 85 degrees and 4,600 ft elevation
202,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
CMCGINNIS13
  • 5 POSTS
After running for an hour, I close the low pressure side and turn off the vacuum. It holds there for over an hour. I assumed it was due to elevation so I tried to start filling the system with R134A. After starting the car and turning on both A/C at full blast, I open the can of 134 and slowly open the low side, the refrigerant will not flow and my low pressure side jumps to 110 psi. My compressor never turns on.
Jul 11, 2019 at 1:22 AM
Good morning,
Was there an issue prior to this procedure?
Did you check for power to the compressor?
The vacuum is normal for the altitude.
I attached a diagram for you. Check the fuse circled for power on both sides.
Jul 11, 2019 at 1:30 AM
CMCGINNIS13
  • 5 POSTS
Thank you for your response. I recently serviced my A/C system and went for a test drive. The engine temperature was almost red lined while running the A/C system. I turn it off and my temperature came back down, after I got home I turned the A/C system back on and realized my compressor was never turning off. I read somewhere that to replace the low pressure switch the system needed to be emptied. So I had that done and replaced the switch, now it does not come on at all. I checked the fuse and the relay and there both okay.
Jul 11, 2019 at 1:50 AM
There is no such thing as the low-pressure switch needing to be emptied.
Do you have voltage at the low-pressure switch?
Jul 11, 2019 at 2:06 AM
CMCGINNIS13
  • 5 POSTS
Yeah, I found that out the hard way. I will test for power at the switch and also at the compressor. Unfortunately I’m at work right now.
Jul 11, 2019 at 2:18 AM
Okay let me know.
Jul 11, 2019 at 2:34 AM
CMCGINNIS13
  • 5 POSTS
I had to jump the low pressure switch to get power at the compressor. Doing so made the compressor turn on but the system will not pull the Freon into the system. The low pressure and high readings jump to 95 psi both.
Jul 12, 2019 at 12:52 AM
Okay, so you have 95 lbs on both sides and the compressor will not engage? Is that correct?
When it engages, what happens to the pressures?
Are your Schraeder valves working?
Jul 12, 2019 at 1:01 AM
CMCGINNIS13
  • 5 POSTS
Yes that is correct. 95 before adding anything to a vacuumed system. When it engages nothing changes on the gauges. As far as I can tell my schraeder valves are working.
Jul 12, 2019 at 1:48 AM
It sounds like the valves are not allowing Freon into the system.
Jul 14, 2019 at 8:57 PM
