A/C turns on but no air comes out
99,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
LILIAPACHECO003
when i turn on the a/c it turns on perfectly no weird sounds or anything but the air vents inside are not blowing air at all, changed the fuse but that did not work and it has the right amount of freon.. i really need help i have no idea what else it could be, i have a 5 month old and it's not easy without the a/c in miami when its always 98 degrees. please if you can help me out that would be awesome!
Jun 23, 2015 at 2:29 AM
JDL
  • 16,098 POSTS
Does the hvac blower motor work? Can you hear it blowing? If the answer is yes, you need to check hvac actuators under the dash.
You could remove blower motor and try to see if anything blocked? As far as the actuators, you'll need to get under dash, which can be a pain, for me, anyway.
I can only recommend things to check, you have to do the testing.
Jun 23, 2015 at 2:57 AM
