A/C troubles
120,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHAEL WRIGHT2
  • 10 POSTS
So, one day my A/C just stops blowing cold air. I checked the fan relay's and they are fine. Then, I had Freon put in it, it blew a little cold, but not like it used to. When I turn the A/C nob to the on position it makes a small kind of noise like a hand rubbing down a dry mirror. If you are not listening you could not tell. I am wondering if I have a clogged orifice valve or do i need a new compressor? Any advice?
Jul 26, 2017 at 7:17 AM
  • 55,676 POSTS
You could need a new compressor but to be sure we need to connect a gauge set to it.
Here is a guide that will help you confirm the problem.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 28, 2017 at 4:24 AM
