A/C blows cold air then stops when speed is below 40 mph
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
JULIE LOPEZ
When on freeway at 60 mph A/C system blows at correct selected pressure and temperature.
Aug 17, 2019 at 4:07 PM
Let's start with what the A/C pressures are with the engine off and then when the A/C is on and engine is on.
If this checks out then we need to see if the cooling fans on the front of the engine are working. Turn the engine on with the A/C on max and see if the fans come on. If not we can go in that direction as long as the pressures are okay.
Aug 18, 2019 at 2:23 AM
