A/C stuck on Defrost?
220,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JROBISON30
It will work for the cold and hot and speeds, but it stays on defrost mode. It won't blow through vents.
Is there a way to manually by hand, put this back into where it blows through the vents only? and not in defrost mode?
Or do I need to reset the fuse?
Thank you
Sep 16, 2022 at 7:38 AM
  • 55,583 POSTS
Not really, the blend door is held by an actuator which you need to replace, (the mode blend door actuator) which isn't too bad to do.
Here is a guide to help walk you through the repair and check the images below so you can see which one it is:
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 17, 2022 at 3:04 AM
