A/C stops blowing
225,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
STNR4U2
A/C stops blowing after a certain speed or when going uphill.
May 27, 2018 at 5:20 PM
Good morning.
I would start by checking the connection at the blower motor itself. It is common for this to be hot and bad connection results.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
May 29, 2018 at 2:01 AM
CJ MEDEVAC
  • 11,000 POSTS
Maybe it is still going but not getting through to you?
I am sort of looking at the possibility of low vacuum to the HVAC controls, sort of "defaulting" the door(s) to another position.
A few possibilities might be:
Engine wear/need of a tune up/possible vacuum lines broken or cracked or not attached. If there is a vacuum reservoir, maybe it is not hooked up.
A vacuum gauge hooked to the intake and ran back into the cockpit might show what the actual vacuum is when this is happening.
I have a "shop gauge" for tuning and one mounted on each of my Jeep dashes. Vacuum gauges are great diagnostic tools for an engine before tearing into one!
Here is a guide for vacuum leaks:
Keep us posted, if you need more information let us know.
The Medic
May 29, 2018 at 8:35 AM
