A/C steaming from vents?
AUTOMATIC
RGABBERT789
Just replaced thermometer because of car over heating, now its been doing this.
Aug 19, 2026 at 12:08 PM
STEVE W.
  • 15,411 POSTS
If it smells sweet it is likely a leaking heater core in the dash. The system works by running air over the heater core and then over the AC EVAP core. So even a small leak in the heater core would travel through the system and show up as steam. If it has overheated the leak may be losing enough coolant to cause air in the system and then it overheats. So does the steam smell sweet and is it leaving any film on the glass? If it is either one it's got a leak. The only solution is replacing the heater core. For that you have to remove the instrument panel to get to the HVAC housing.
Aug 19, 2026 at 11:37 PM
