air conditioner slow to turn on
2009 DODGE RAM
78,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MARTHA LANHAM
air conditioner was slow to turn on before a new switch was put in. Now it is not as slow to turn on but is still slow to turn (about two minutes slow).
Aug 15, 2016 at 12:39 AM
SATURNTECH9
  • 30,869 POSTS
So when you say slow to turn on do you slow to get cold? Or do you mean something else?
Aug 16, 2016 at 8:48 AM
MARTHA LANHAM
  • 0 POST
Hi. I mean it's cold enough, but the fan speed is slow and then slows more. You can barely feel any force of air.
Aug 16, 2016 at 10:35 AM
SATURNTECH9
  • 30,869 POSTS
Alright does the fan speed seem to increase in speed everytime you increase it?
Aug 16, 2016 at 11:40 AM
MARTHA LANHAM
  • 0 POST
If you mean by "increase it" when we turn up the force of air (fan/blower)..,no. When we start the truck, the fan knob is in the highest position. Ittakes about 15 minutes for the fan and cool air to come on. But then in a few seconds, the fan blows only VERY low, almost nothing. The air is still cool. Turning the fan knob down low and then right back up again doesn't do any good. Someone said they think it might be a grounding problem.
Aug 17, 2016 at 4:42 AM
SATURNTECH9
  • 30,869 POSTS
So it blows the same exact speed no matter what speed the setting is on?Also do you have a multi meter to do some testing?You will have to do some testing to help figure this out.
Aug 17, 2016 at 5:31 AM
MARTHA LANHAM
  • 0 POST
No. It's set on high and then goes to a VERY low speed. Yes, the mechanic tested it and shows the power is going all thru there. I'm hoping you come up with a solution before we take it back to the mechanic on Monday to see if it's a grounding problem. He said there's probably a hundred groundings which are numbered, but he doesn't know which number applies to this issue. He said a connector may be getting hot and shutting it down. Do you know about grounding and connectors re this? Thx!
Aug 17, 2016 at 7:17 AM
SATURNTECH9
  • 30,869 POSTS
Yes I do but we still have to do some testing with a multi meter to find the problem.Like on high of its getting full battery voltage but it still loosing speed then you could have a bad fan motor.
Aug 17, 2016 at 11:21 AM
MARTHA LANHAM
  • 0 POST
The mechanic already put on/in a new fan motor, a new switch, and some kind of small box that wires are hooked to on.
Aug 17, 2016 at 11:06 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like the resistor your talking about.So do you have a multi meter to do some testing?Going to have to do some testing to see what's going on.There has already been a lot of parts replaced and still hasn't solved anything.Do you have auto climate control or manual controls?
Aug 18, 2016 at 5:20 AM
MARTHA LANHAM
  • 0 POST
My husband has a multi meter. It has dual auto climate control, but it always seemed both sides of vents put out cold air based on the coldest of the two settings. Maybe we weren't using it correctly. I didn't understand what the manual said when I read it about this.
Aug 18, 2016 at 5:41 AM
SATURNTECH9
  • 30,869 POSTS
Do you actually dial in the temp number or is it just a red blue adjustment?Also has anyone scan the AC computer for codes?that would take a professional scan tool not s diyer scan tool to do that.
Aug 18, 2016 at 10:32 AM
SATURNTECH9
  • 30,869 POSTS
Depending on the scan tool sometimes you can control the AC blower fan AC doors etc.
Aug 18, 2016 at 10:33 AM
