Blinking light on the A/C button on the dash
170 MILES • 1.8L • 4 CYL • 2WD • MANUAL
CHRIS ROSADO
I have a blinking light on the A/C button on the dash. I have seen many videos telling me is the relay, but I went to a car mechanic and he told me I need a new compressor and condenser because he thinks the compressor is dead and since that happened the condenser might be clogged and wont work. So my repair cost is $1,600.00. I don't know if is a reasonable price but it seems too much even when I think I could be the relay like the videos I've seen say.
If I change the relay and the compressor starts working is there a risk in damaging something?
Thank you!
Aug 26, 2019 at 9:25 PM
Good morning.
Does the compressor engage when you turn on the A/C?
Did he check pressures for the system? That would be the first thing I would have done.
How did he determine the compressor was bad?
Expensive guess here without facts to back it up.
Aug 26, 2019 at 9:37 PM
CHRIS ROSADO
Well, he said the car was low but now the pressure is good. The answer I got to why the compressor was bad is because he says there's a relay switch in the compressor (internal) that kicks on when the A/C is on but then it goes to a infinite impedance after thirties.
The A/C button in the dash turns on when the A/C is activated and I can hear the compressor on after thirties the compressor goes off and the A/C button starts blinking.
Aug 27, 2019 at 4:52 AM
Wow, that is way out there and totally incorrect on the compressor.
What are the pressures?
I would get your car out of there and to someone who knows something about air conditioning.
Aug 27, 2019 at 5:49 AM
CHRIS ROSADO
I was thinking in changing the relay since every video on YouTube I've seen that's the problem, but I want to know that if I change that relay and the compressor starts working would something else go wrong like for example the condenser or other A/C components?
Aug 27, 2019 at 10:11 AM
Again, is the compressor engaged with the A/C on?
I need to start somewhere and I do not guess. I do not care what YouTube says at all. This is real and your car.
Aug 27, 2019 at 10:54 AM
CHRIS ROSADO
Yes it engages with the A/C but only for 30 seconds and then the A/C button on the dash starts blinking and the compressor stops.
Aug 27, 2019 at 12:43 PM
I need the pressure when the A/C is engaged.
Aug 27, 2019 at 6:21 PM
