engine light is on
69,000 MILES • 4.3L • 6 CYL • 2WD • MANUAL
RICHARD BREWER
Would the A/C being messed up make the engine light stay on?
A/C relay purple wire burnt, wire going to the A/C compressor was melted off, broke off.
Dec 7, 2017 at 10:01 PM
  • 55,758 POSTS
Just make sure the wiring is not touching anything. You should run the codes to see why the light is on.
Here are two guides take the one you need:
and
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Cheers, Ken
Dec 9, 2017 at 11:26 AM
