A/C relay location
2003 TOYOTA MATRIX
196,000 MILES
CARLITOS 1511
need to know location of A/C relay.
Apr 13, 2017 at 4:29 PM
HMAC300
  • 48,601 POSTS
the air conditioner compressor relay is called a M/G CLT relay under the hood here is a guide to help test it with the location of the fuses and relays below.
Apr 14, 2017 at 12:40 AM
KOOLAIDGUY1
My ac clutch will engage but it does not get my car cold. I started to try to fill it with refrigerant, and at one point the clutch stopped engaging, and when i looked at the pressure it was in the danger zone. It was really hot out that day, and i dont know if i was reading the ressurr correctly or if the clutch had to be angaged to read it. How will i know if i overcharged it?
Also, last week my ac was working but it would only work sometimes.
Sep 25, 2019 at 10:53 AM (Merged)
HMAC300
  • 48,601 POSTS
hard telling for us because we don't know what you did. have a pro run a performance test on it it may not even need Freon may be an actuator inside car.
