A/C refrigerant leaks at fill port
2009 FORD F-150
120,000 MILES • V8 • AUTOMATIC
TECH2020
  • 41 POSTS
My stepson replaced the A/C Refrigerant Liquid Hose in his truck listed above as he stated it was bad. He charged the system via connecting to the port on the new hose (metal line). The A/C worked for a short time then he found the refrigerant leaked at the filling port. He replaced the hose (metal line) with a new Motorcraft part and the same failure happened again. Is he doing something wrong or is this a common problem? What to do?
My stepson has done extensive auto repairs.
Thanks,
Tom
Oct 19, 2021 at 11:02 AM
CARADIODOC
  • 34,381 POSTS
They all leak a little. The purpose of the valve stem is to hold the refrigerant in long enough to give you time to screw on the cap. There's a rubber o-ring inside the cap that does the real sealing.
Here's links to some related articles for the benefit of others researching this topic:
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Oct 19, 2021 at 11:39 AM
