Front A/C not blowing only cool air not cold
140,000 MILES • 3.5L • V8 • 4WD • AUTOMATIC
JURIBE0713
Today I did a recharge and it seem to work so the back A/C is blowing cold air then the front air.
The front air getting cold but not too cold. I already change the blend actuator. So I don't know what else that needs to be done.if anyone knows something let me know please. thank you
Apr 28, 2020 at 12:14 PM
Good afternoon,
Can you give me the high and low side reading of the A/C system with the engine running and the A/C on?
I need to see them in order to see if the system is working properly.
How much Freon did you install?
Apr 29, 2020 at 2:45 AM
JURIBE0713
Thanks you for getting back to me.
I installed 20oz Freon into the truck I used the A/C pro can with the hose.
How can I check the reading of the high and low ?
Apr 29, 2020 at 4:58 AM
You need a set of pressure gauges. You can get a cheap set at harbor freight.
https://www.harborfreight.com/ac-r134a-manifold-gauge-set-62707.html?_br_psugg_q=ac+gauge
Once you get them, hook them up and watch the readings when you turn on the A/C system. Tell me or take a picture and post it here so I can see the readings.
I may be either low or too much Freon in the system.
Apr 29, 2020 at 5:05 AM
