System is charged and high pressure side only reaches 140 psi and had to get the low psi side to 70 psi to build the high side to 140 psi. At at optimal low psi at 45 psi it only gets up to 130 psi on the high pressure side. Compressor is engaged constantly. I believe it could be a bad compressor pump. Wanted professional advice before changing the compressor.
May 8, 2018 at 11:11 AM
