I recently changed my air conditioner compressor. If I turn on my AC then the AC light will be blinking and the AC well not cool.
Feb 6, 2017 at 12:16 AM
STEVE W.
✓Experienced Mechanic
The most common cause of this is a bad MG CLT Relay. Take a look at the clutch and see if it is engaging. If it is you may have an undercharged or overcharged system.
If you have access to a scan tool that can read the HVAC modules codes it will give you a clue with the code that is stored.
