A/C cold on right side warm on left side?
100,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
RAY PRICE
A/C problem.
Jun 5, 2024 at 12:24 AM
  • 55,711 POSTS
The most probably cause is the A/C system is low on refrigerant. This car does not have dual climate controls, correct? My information shows it does not, if it did, I would call the driver's side temperature blend door actuator as being bad. Here is a guide to help you check the A/C refrigerant level and then add some if needed:
https://youtu.be/-mikngtS63w?si=fxFAUKt0Pe6REBY_
Please go over this guide and get back to us.
Jun 5, 2024 at 10:34 AM
