A/C problem
70,000 MILES • MANUAL
JAMISON GARZAREK
When I turn my A/C on on the lowest setting the A/C light comes on but there is no air. When I turn it to the other three settings the light goes off and it blows hot. Also, my radio does not work and I have checked all my fuses none are blown. About six months ago someone was replacing my battery while I was over seas and they crossed the cables and it blew out the alternator, ever since then nothing seems to work. I did not know where I should start to diagnose the problem because before that happened everything worked fine. Thanks
Jun 30, 2017 at 3:10 AM
  • 55,711 POSTS
It sounds like the climate controller is blown out as well. It happens when you cross the cables. Sorry, common mistake.
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 2, 2017 at 12:44 PM
JAMISON GARZAREK
Was the blower motor resistor.
Mar 11, 2018 at 7:20 AM
  • 55,711 POSTS
O not to bad then, lucky you :) Thanks for getting back to us.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Mar 12, 2018 at 4:27 AM
