A/C problem
JIM KAMINSKI
  • 2005 CHEVROLET IMPALA
  • 6 CYL
  • 140,000 MILES
A/C compressor is not engaging I jumped the relay and it worked. So I checked the Freon and it was on the low side, but should be enough to start compressor. Went down and got a new relay but still nothing. Not sure where to check next or what would cause the compressor not to start.
Sunday, August 13th, 2017 AT 4:52 PM
  • 31,937 POSTS
If the refrigerant charge is too low the low pressure cut out will not allow the compressor to kick in, this is a protection device as the compressor can be damaged if run low on gas. Fill the system with the correct weight of refrigerant and get a leak test done. If the system is low you will have a leak to repair.
Monday, August 14th, 2017 AT 3:54 AM
