A/C problem
190,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SAM CARLESE
When i am driving and i have my A/C on at times the air will blow warm and then it will blow cool again had Freon checked and it is okay.
May 18, 2017 at 8:08 AM
  • 55,797 POSTS
It sound like you have a blend door actuator that is going out, here is a guide that will help you get the problem fixed.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 22, 2017 at 3:34 AM
DARRENCO1
  • 10 POSTS
Air Conditioning problem
2000 Lincoln Town Car V8 Two Wheel Drive Automatic 95000 miles
checked air con compressor low and high pressure switch, relays, fuses and self diagnostic on dash.
gas full and checked by air con specalist.
no codes
you can by pass the compressor to make it work so i now thats ok
any help would be appricated.
May 22, 2017 at 3:35 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Is it getting signal through the cycling switch (low side)? If pressures are good, then it is electrical,need to find out where the signal stops. Do you have a trigger signal at the relay from the PCM? Does the relay have power ? Is the ground good at the compressor?
DARRENCO1
  • 10 POSTS
thanks for quick reply i have just checked power to pcm fine and relay and switches, earth good at compressor
2CARPRO JACK
  • 11,533 POSTS
Is it passing the power through the cycling switch (low side)when a/c is on?
DARRENCO1
  • 10 POSTS
im getting positives at this relay removed
https://images.2carpros.com/forum/automotive_pictures/75566_R0013890_1.jpg
https://images.2carpros.com/forum/automotive_pictures/75566_R0013892_1.jpg
13 v through b/w wire on low presure switch
2CARPRO JACK
  • 11,533 POSTS
is this a Cartier, Signature or Executive series?
TACKLEMAN
Heater problem
2000 Lincoln Town Car V8 Front Wheel Drive Automatic 114000 miles
The EATC does not work. The heater/AC panel lighte up and all the controls work. all the fuses marked EATC are good. What could be the problem? Help!
2CARPRO JACK
  • 11,533 POSTS
The relay shoul dhave power at 1 more spade with engine running, then th elast one3 should ground when a/c turned on (signal from PCM) the signal wire is orange/ lt blue
CUSTOMERSERVICE
It seems likely that either your blower motor is bad, or your blower motor controller is bad.
I personally own a 2000 Lincoln Town car. Mine also has EATC (Electronic Automotic Temperature Control). With this setup an electronic blower controller is used in place of the blower resistor. The blower controller is located inder the hood, nearly centered with the car, but slighty toward the passenger side. It is mounted in the HVAC ductwork just behind the engine. Removing the cowling made access a lot easier for me, when I was replacing mine.
Good luck,
Tony
TORHOF
2000 Lincoln Town Car V8 Two Wheel Drive Automatic 125000 miles
AC works fine (cools down to 45F), but stops working and blows hot air into the car as soon as the outside temperature reaches 84F or more.
The stop comes earlier if it runs with max AC. If it is set on automatic AC, I think it runs longer.
Even after long drives and hot temperatures (with hot air blowing into the car), the AC comes back by itself if the outside temperature falls below ~84F.
I replaced the coolant already twice (by a professional, he also checked for leaking, but said everything looks fine). A Ford dealer checked it for a day, but found nothing.
DARRENCO1
  • 10 POSTS
power on two terminals only with air con on or off cartier edition lincoln
thank you
BMRFIXIT
  • 19,053 POSTS
Check for codes
Ensure coolant temperature is at least 120°F (49°C) before entering self-diagnostics.
Ensure in-car temperature is between 40-90°F (4-32°C).
Simultaneously depress OFF and FLOOR buttons, then press AUTO button within 2 seconds.
Display will show a dashed line in the center of the display window for up to 30 seconds while test is running. Record all DTCs as displayed.
check and suspect sunload sensor
check coolant fan operation
check if system was over charged
FIXITMR
  • 9,989 POSTS
did that solve your problem?
2CARPRO JACK
  • 11,533 POSTS
did you test for ground at the orange/lt blue when a/c is on? (one of the other spades at the relay)
DARRENCO1
  • 10 POSTS
hi im getting red/black +
biege /cream earth
orange/black+
orange/dark blue earth constant
nothing seems to change air con on or off when reading from under pcm engine on
ANONYMOUS
  • 0 POST
air conditoning is not cooling
2CARPRO JACK
  • 11,533 POSTS
Im going to suggest that you go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
This is to Mitchell, the online program used in shops.Go to "electrical", "wiring diagrams", "a/c" there you will see the entire circuit so you can match up the colors to see what is going where
  • 75,988 POSTS
Have the high and low pressure checked-could be low/no freon in it-start here
