Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ram
1500
Climate Control
Air Conditioner
Compressor
Clutch
A/C only cold when moving
2004 RAM 1500
155,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JKOLNITYS
MEMBER
1 POST
The A/C compressor clutch switches on and off when stopped and when I checked the pressure when stopped, it showed it running high (60+ psi).
Jul 15, 2019 at 7:44 AM
Experienced Mechanic
Good evening,
Is that the low side or the high side? I would like both readings if possible.
Is the cooling fan working when you are stopped? It has to be on to draw air through the condenser to cool off the Freon.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Image (Click to enlarge)
Jul 15, 2019 at 8:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
