A/C not working properly?
270,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
On a hot day starting the vehicle and putting the A/C on max it does not blow cold while the vehicle is parked but once i start driving it gets cold. I can then park the car After driving and it still stays cold. What would be causing this? Thank you so much for your help.
May 12, 2023 at 10:12 PM
  • 110,248 POSTS
The first thing I would check is the freon in the system. If it is a little low, that can cause a delay. Take a look at this link, it explains how to recharge the system:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
This is the first thing I would try. Also, keep in mind, when you are sitting still, the compressor is turning a lot slower than when driving. Does it start warm regardless of how long you wait before driving?
May 14, 2023 at 1:09 PM
