I turned it on and I felt cool air for a split second then immediately hot
277,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
TMCINTOSH11
  • 176 POSTS
Hi guys, I've had this truck since mid march and recently I thought I'd try and see how the A/C did, so I turned it on and I felt cool air for a split second then immediately hot, so I checked the fuses and the one for the A/C clutch was missing so I put one in it, tried it again got cool air for another split second then just warm air, not as hot as last time but still not even close. So I'm guessing maybe I should check the pressure in the system and see if it needs recharge? I've rarely ever worked on A/C systems before, I've recharged a few systems before but nothing major. If it turns out that the system is fully charged what would I need to do from there? I tried Googling diagnostics for A/C systems but every answer pretty much ends with going to a certified tech, I mean I could go to one but it'd be nice if I could save some money, especially if it's something small or simple.
May 26, 2021 at 11:03 AM
  • 110,244 POSTS
It could be several things. First, do you notice if the A/C compressor engages? If not, it could be low Freon, a pressure sensor, a wiring issue, or a faulty clutch.
Take a look through these two links. The first one discusses common causes of it not working and the second is how to recharge.
If this doesn't work, I will need to know both the high and low pressures.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know what you find.
Jun 23, 2021 at 2:37 AM
