Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Liberty
Climate Control
Air Conditioner
Blows Hot
A/C blows hot air and A/C clutch keeps turning on and off
2006 JEEP LIBERTY
180,000 MILES • 2.4L • V6 • 4WD • AUTOMATIC
REA4444
MEMBER
I have filled with coolant and have checked the fuse and relay. The serpentine belt looks good.
May 24, 2020 at 2:24 AM
Experienced Mechanic
Good afternoon,
Do you have gauges to give me the high and low side readings? I need to see them to see if the A/C system is working correctly.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
May 24, 2020 at 3:33 AM
REA4444
MEMBER
No.
May 24, 2020 at 7:05 AM
You can rent a set or buy a cheap set to check the pressures.
I need these pressures to help you solve your issue.
May 24, 2020 at 7:07 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
