Welcome to 2CarPros.
The first thing I suggest is to disconnect the connector to the compressor and see if the fuse still blows. If it does, there is a problem with the electric clutch. If it doesn't then you need to trace wiring to find where the short is located. Keep in mind, the AC switch itself can be bad too.
I have attached a few pictures of the wiring schematic for you.
Picture 1 shows the power wire at the compressor electromagnetic clutch. It is a black wire with a white tracer. Disconnect that and see if the fuse blows. If it does, take a look at the rest of the pictures. Power runs from the switch via a white wire with a black tracer. It connects the with the switch, ground, and AC amplifier on the right side of the instrument panel. You will need to follow that wire to see if there is a bare wire, or something causing it to short.
Here are a few links that you may find helpful when checking wiring:
Images (Click to enlarge)
May 7, 2019 at 11:58 AM
