My car's AC is blowing only hot air. The light indicator also does not turn on when I press it. Can it be the electrical?
Jun 22, 2018 at 6:57 AM
✓Experienced Mechanic
Good afternoon.
Yes, it can be electrical. If your Freon level is low and the pressure drops below 20 lbs, the system will not work to prevent damage to the AC system.
The AC system needs to be checked for Freon pressure first. Beyond that the circuit for the system needs to be checked.
