A/C not blowing cold?
145,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
JOHN VICKERY
When outside temperatures get above 75 degrees my A/C will only blow luke warm air. If it is under 75 degrees it will start blowing cold again.
Jun 20, 2023 at 2:38 AM
  • 55,746 POSTS
It sounds like the system is a little low on refrigerant or you have a programming issue. I would check the low side pressure by following this video.
https://youtu.be/4EqdrBVb0sY
and
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If the pressures seem okay, I would try resetting the HVAC system by following this guide:
https://www.2carpros.com/articles/step-by-step-guide-to-reset-your-cars-hvac-system-an-essential-for-every
If that doesn't work, we need to do a CAN scan which will go over the HVAC system, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us because it might be the temperature sensor. Check out the images (below). Please let us know how it goes.
Jun 21, 2023 at 4:13 AM
JOE VICKERY2
The refrigerant was low and when I added more it fixed the issue for now.
Jun 24, 2023 at 12:16 PM
  • 55,746 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jun 25, 2023 at 4:44 AM
