A/C not blowing cold
160,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BURBANBOY
  • 5 POSTS
Hello, I have the SUV listed above that will not blow cold air. Tried recharging the system and it did not work, what would be the next plan of action?
May 3, 2020 at 1:52 AM
Good morning,
I need the high and low side readings of the system. You can rent a set of gauges at a parts store or buy a cheap set at Harbor Freight.
Does the compressor come on line? I will attach a wiring diagram for you to view. If you have a test light or volt meter, we can do some checks.
May 3, 2020 at 3:00 AM
