A/C not blowing cold air?
118,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
DOUGLASBEGIN7
The A/C was not blowing cold, Freon was added, but still hot. I had compressor and A/C system replaced. Compressor Oil checked and still not blowing cold. Cabin filter replaced. Vent door checked and working. Still not blowing cold. How to check sensors or control panel? What other causes?
Aug 12, 2023 at 12:12 AM
  • 55,673 POSTS
With the A/C on full cold, grasp the outlet tube from the fire wall (firewall to compressor) at the firewall to see if it is cold, if not I will need the high and low side pressures, this video will show you how:
https://youtu.be/4EqdrBVb0sY
This guide may help as well:
Please go over these guides and get back to us.
Aug 12, 2023 at 8:49 AM
