A/C no cold air
134,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
HUNTERVANWYHE
The car listed above is a gtp model.
A/C always worked then one day it stopped blowing cold air. I can see the compressor turning. I tried a bottle of subzero. When I put it on and pulled the trigger it would go straight to the red zone. I'm not sure what to do.
Aug 11, 2019 at 8:10 AM
Good afternoon.
You need a full set of gauges to see the high and low side readings.
If the compressor is engaged, you may have a bad compressor but needs to be confirmed with the gauge readings.
Aug 11, 2019 at 8:27 AM
