Where is the A/C Low Pressure Switch located?
110,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
SPILLCO
Where is the A/C low pressure switch located? cannot locate the low pressure switch.
Mar 5, 2022 at 11:12 AM
  • 110,248 POSTS
I believe there is only one pressure sensor on this system. It should be located on the liquid line.
If you look at pic 1 below, it shows the wiring schematic for the system. Pic 2 shows the pressure sensor location on the liquid line.
I'm not sure what is happening, but here is a link you may find helpful. Take a look through it and let me know if you have questions.
Mar 5, 2022 at 2:11 PM
