I replaced all components of my A/C system last summer (except for the evaporator). I put the PAG oil in according to the manufacturer's instructions. I vacuumed the system, and it held the vacuum. I then charged it with the required amount of refrigerant. It worked GREAT, but only for about 24 hours. When I put the manifold gauges on it, the system had no pressure. I'm stumped.
1.) Why would the system have no leak under vacuum but lose all refrigerant when under pressure?
2.) Provided I can find the source of the leak, will I need to add PAG oil? (I know that vacuuming the system down doesn't remove the PAG oil, but would I have lost any due to the leak (wherever it is))?
3.) In the event that I need to add PAG oil, is there a simple way to determine how much, or do I need to drain the oil from the compressor and then fill it with the specified amount. I know that too much oil reduces the effectiveness of the refrigerant and will decrease the cooling capacity.
4.) Is there anything else I should be aware of?
Thanks,
Chuck
Thanks,
Chuck
Jun 24, 2022 at 7:49 PM
