Compressor was making a noise. Hooked up a gauge and read high pressure on the low side. Recovered some of the refrigerant to release said pressure and topped back off to the correct pressure. Compressor does not make noise anymore and sounds and looks like it is running normal, however air isn’t too cold anymore coming out of the vents. Could this be a compressor issue still, or possibly that the system needs to be placed under vacuum before being filled back up? Also seems like the clutch didn’t want to disengage when I recovered some of the refrigerant. Recovered enough to where the clutch either should have disengaged or at least cycled.
Jul 24, 2020 at 3:08 AM
