front and rear A/C blows hot air . dye use was no help.
May 22, 2017 at 2:59 AM
✓Experienced Mechanic
Yep sometimes the dye will not show up which is normal. the best way to find the leak is to use a leak detector, here is a guide that will show you how to get the job done.
